mx 67 no acepta cambios de ip
ANTHONYNETREADY
saludos he tratado de cambiar ips en un mx 67 y me lanza este error
sabra alguien como solucionarlo le a sucedido a alguein mas ?
mil gracias de antemano .
Often mx config only accepts adresses where it has a vlan/subnet  or static route for on that mx.
If 172.23.1.11 & 200 is configured somewhere in the meraki config you have to remove it.  (For example in the source field of your firewall.)
If you trying to add those ip. Its not possible to add ip adresses that the mx not know on the lan side
ANTHONYNETREADY
Thanks for your help, friend. I'll tell you
this is the only part that doesn't take the change.
I've already deleted and changed everything as far as I know, but this reappears
It's look like a configuration in your DHCP configuration.
Do you have any setting on the DHCP page?
