It can be tricky - and there are several factors to consider (i.e. are downstream switch and APs using static or DHCP IP addresses)?
1. I typically create the new subnet/VLAN at the MX (192.168.1.0/24). If it that subnet/VLAN exists already, go to step 2.
2. I would then change the (switch/AP) device IP addresses and VLAN if static. If DHCP, then change your VLAN ID on the device. And quickly thereafter make adjustments to the native VLAN TRUNK uplink/downlink ports.
3. The last step would be to change the native (management VLAN) on the switch settings page last.
Others might do in sequence differently - this has worked for me every time. Hope it helps and good luck.
