switch 9300 vlan ID 1100,1200
shlomoi
I'm trying to create a new vlans on the switch 9300L ,on the uplink trunk port
vlan id 1100
vlan id 1200
I get an error message that it is not possible to establish more than 1000 vlans .
I don't have 1000 vlans. I have about 30 vlans but some of them are over id 1000
is it possible ?
shlomoi
working!!!!
Thank you very much
6 Replies 6
RWelch
Not sure if related or same scenario but sharing in the event it helps you:
C9300-M VLAN 1-1000 quirks
Catalyst 9300/X/L-M Series Installation Guide has a NOTE about VLANs outside of 1-1000 for your consideration.
shlomoi
Hi, I tried as in the guide but it doesn't work
Mloraditch
The list must be less than a 1000 vlans total. Your list is well over a thousand
So 1-998,1100,1200 would be valid for an example or 1-500,600-700,1100-1200 and so on
rhbirkelund
Start by changing the allow list to something less than 1000 vlans in total, e.g. VLANs 1-200.
Save the config.
Then edit the ports again, and then add the VLANs to the list that you need.
shlomoi
working!!!!
Thank you very much
  • 802.1Q VLAN and trunking support for up to 4,094 VLANs (1000 active VLANs with STP enabled)
https://documentation.meraki.com/MS/MS_Overview_and_Specifications/MS390_Datasheet#MS390_Licensing
