No, but you could control this simply by selecting an appropriate port.
Port 1 has the highest default port cost, port 24 is lower, and port 48 is lowest. Lets pretend you have a 24 port switch on each end. If you plug your preferred circuit into port 24, and the backup into port 23, and both ports have the same speed configured, port 24 will win and port 23 will block.
And now you now why people often use the last ports on a switch as trunk links to other switches.
