c9300 Onboardin
Merak_tree
c9300 Onboardin
I have replaced c9300 with same model in switch stack of 2 but the replaced switch still shows in the Meraki Dashboard, which is now showing dormant.  Do I need to remove old switch from the dashboard or simply run the Cloud Monitoring for Catalyst process and it will sort itself out.  I am new to this and trying to learn and all your help is greatly appreciated!  Thanks in advance!
I'm not sure.  But you will need to re-run the onboarding tool.  If you have an extra dormant switch in the dashboard afterwards, remove it.
Note that there is now a cloud native IOS-XE which is more reliable when it comes to interfacing with Meraki.
https://documentation.meraki.com/MS/Cloud-Native_IOS_XE
5 Replies 5
RWelch
Getting started: Cisco Catalyst 9300 Management with Meraki Dashboard
Merak_tree
I re-ran the onboarding tool at it did clean itself up.  I really appreciate guys for your responses!  Great community to be a part of!
Inderdeep
You got the answer from the legend of our community @PhilipDAth
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
CarolineS
Meraki Alumni (Retired)
Thank you for the compliment about the community, @Merak_tree! I marked this thread as solved as Philip's answer seems to have fixed your issue.
Cheers!
