What OS version is used in MS250-48FP
teja
i am preparing a document and require the OS version installed in devices , How to verify which OS version is used in
MS250-48FP . Is there anyway we can check this information from our dashboard.
Is there any specific name for OS that is installed across the meraki devices as all devices carry same OS as per meraki website.
6 Replies 6
You can check it on the Firmware upgrades.
https://documentation.meraki.com/Firmware_Features/MS_Firmware_Features_Directory
teja
what is the name of the OS , in legacy cisco devices we have cisco ios and cisco ios xe , what is the OS called here in meraki  ?
ConnorL
Meraki Employee All-Star
We don't have any particular name for the OS it runs, Meraki devices run Meraki OS.
MR runs MR firmware, MS = MS firmware etc.
RaphaelL
It's MS X.XXX
MS for Switch, MX for Firewalls, MR for Wireless, etc.
On the switches page you can add the column Firmware Version and then you will see them all as below (usually with Name and MAC address columns that I have removed to post here:
