VLAN - Issue
Haris
Just browsing
VLAN - Issue
VLAN 110 used as trunk for uplink ports in meraki switches
And at same time VLAN 110 if assigned to any other ports doesn't works with dhcp.
It gives apipa range only.
4 REPLIES 4
bvdijk71
Can you provide a bit more information?
How did you exactly configure your uplink?
From Meraki (model?) to 3rd party switch?
Did you configure DHCP Relay, where?
Mr_IT_Guy
Is the port connected to the uplink set for 110 as well?
Yes it was . I changed the native port to some other VLAN
Now the VLAN 110 is functioning well.
DensyoV
It could be an issue if there is a native VLAN mismatch on the trunk ports or if the VLAN is pruned.
Just ensure the trunk port configuration is the same on both ends.
Thanks,
Please hit kudos if you found this post helpful and/or click "accept as solution" if this solved your problem.
