Hi Bruce,
First of all, I made an error on my initial statement: The switch stack are all MS410-16 switches.
port 17 on the switch A has the following SFP:
SFP module | CISCO-AVAGO - 1000BASE-T: 1.3 Gbps |
Yes all switches in the stack go down.
Switch A and B in the stack have port 16 connected to the router in an aggregation (LACP)
Only switch A has a port 17 connected.
Switch C is more of a backup with very limited connections.
Performing a soft reboot on the switch A via the cloud portal kills the whole stack and we get somewhere a loop of traffic because there is about 340Gb/s passing through these switches.
Only after hard rebooting (power down/up) all 3 switches, things got back up.
To be more clear and make things complicated, the catalyst switches are in between two Meraki MS switches.
And a dot1q tunnel is created between the ports of the catalyst switches on each end where the Meraki switches connect to.
So you get this:
MS220-8P (port 8 -----> Cisco catalyst --> Cisco catalyst --> fiber port to MS410-16 (port 17)
trunk <----------------------- dot1q tunnel vlan 104 -------------------------> trunk
(vlans 602, 605, 10,20) (vlans 602,605,10,20)
So there is no real STP negotiation with the Catalysts for the vlans in the trunk.
The reason for such an ugly setup (let;s face it, it is) is the catalyst switches belong to the customer network and there are used for other purposes. Additional fiber connections cannot be provided or created due to the location of the sites.
