I am still new to Meraki so I have a very basic question.
When stacking C9300 switches, do you go into the local status page and assign IP address info and then the entire stack uses that same IP address, or do you need to assign a different IP address to each switch in the stack?
I did see this so I am thinking they do not.
When using static IP addressing for switch management interfaces rather than DHCP, the management IP address cannot be individually altered for each stack member through the dashboard. Once the stack is configured, all members will display the management IP address of the active (primary/master) switch, where the control plane resides. It is important to note that if a change to the management IP is made after the stack has been configured, that change will apply to the active switch and will be reflected across all stack members. The management IP is shared and not unique to each switch within the stack.
Note: Due to the management IP behavior described above, accessing the Local Status Page from any member will direct to the local status page of the active switch, regardless of which stack member you are physically connected to.
