We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
Hi When i click Switch in left column on dashboard, and then we can see there are several switches listed there. but one of switch has orange status. What does that mean? Thank you
Solved! Go to solution.
showing a Alert...
when you click on the switch, which is shown orange, you should see a notification.
Had that regarding to a missconfigured DNS Server
It just means the 1Gb speed negotiation failed and speed is downshifted to 100Meg.
the orange status is not for switch port, it is for the switch. please see the below:
Sorry @Merakibgp I saw switchport status. As @NolanHerring stated DNS or VLAN most likely.
Thank you all. some vlan was mismatching
