Stack Fail?
Stack Fail?
This is a hypothetical question,
in case of 5 stacked switches MS225 (using physical stacks)
the third switch from the top failed (let's say power failure)
will the remaining 2 switches below be still stacked and function properly?
or if a switch in the middle failed will cause the rest of the switches to get disconnected from the STACK?
appreciate your feedback.
Accepted Solutions
Re: Stack Fail?
Hi @ahmadtat
The bottom two switches will still remain part of the stack as the bottom switch will be physically connected to the top switch of the stack.
Darren O'Connor | uccert.co.uk
3 REPLIES 3
Re: Stack Fail?
Hi @ahmadtat
Re: Stack Fail?
Thanks @UCcert  for your confirmation
Re: Stack Fail?
Hi @ahmadtat
Further useful information on stacking can be found here
https://documentation.meraki.com/MS/Stacking/Switch_Stacks
