Is it possible to copy just a single port configuration from one switch to another?
I would probably use the API for this.
First just GET the config from one port on one Serial, then PUT it back to the other port.
I single port - no (you would need to use the API like @Rebry says). Personally, I'd just open up to windows side by side so you can see both the old and new port at the same time.
