Specifying more than one DNS server in custom name servers
Silas
I have a Meraki MS switch that it serving up DHCP for my wireless clients
However, I can't seem to specify more than one custom name server in the DHCP scope on the switch. If use the syntax
172.25.1.10 , 10.10.10.1
or
172.25.1.10,10.10.10.1
it doesn't take it.
How do I do this? (can't find it anywhere in the documentation)
WadeAlsup
If it's anything like setting Custom DNS on the security appliance, put one IP per line with a carriage return (press enter) between.
172.25.1.10
10.10.10.1
Found this helpful? Give me some Kudos! (click on the little up-arrow below) and If my reply solved your issue, please mark it as a solution 🙂
2 Replies 2
WadeAlsup
172.25.1.10
10.10.10.1
Silas
yep, that worked
thanks!
