Setting up a new switch
MJohnson21
I am new to this job & I need help setting up a new switch on our network. It is a MS 120-8FP-HW switch & I can'
t seem to get it to connect. I have followed the set-up directions, but am having no luck.
If anybody can give me some things to check out, it would be much appreciated.
MS Quick Start
Quick-Start
If you just want to get started without reading more in-depth information, follow these basic steps:
  1. Unpack and mount your switch (desktop or rack mount) and power it on.
  2. Plug any one of the Ethernet or fiber ports into an upstream device on your LAN. The uplink port should have access to a DHCP server and it will also need to be able to communicate with the internet.
  3. After powering on, your switch will download the latest software. While upgrading, the switch's power LED will flash green/white. Once the switch has checked into the dashboard, the LED will turn green/white. Note: A solid orange light indicates that the device has not checked in with the dashboard yet.
  4. Log in to http://dashboard.meraki.com (For any devices that are used in mainland China, please visit http://dashboard.meraki.cn and create a new network. If you do not yet have a dashboard account, choose "Create an Account") Type in the serial number of your switch (found on the back of the unit) or simply enter your order number. This will create a new switch network.
    • Alternatively, use your phone to scan and onboard your devices with the Meraki mobile app (iOS) (Android).
  5. Make your desired configuration changes under the Switch > Configure section of the dashboard.
For additional switch installation information, please refer to the MS Installation Guides article.
MS Quick Start
Quick-Start
MJohnson21
Thank you
BlakeRichardson
All Meraki gear comes with a guide explaining how to connect the equipment. It's probably with the safety certifications page you threw in the bin.
