MX LAG
P4ck3ts
MX LAG
hello,
Can I configure LAG on an MX into an SG switch? or does it only work on MS?
thanks
GreenMan
Meraki Alumni (Retired)
Link aggregation / LACP / 802.3ad is not supported on the MX.  You can still set up dual uplinks to your MX but plan on using the fact that MXs forward STP BPDUs, to enable the switch network to block / unblock links as needed to resolve loops and restore connectivity in the event of a failure.
5 Replies 5
MX doesn't support LAG.
https://documentation.meraki.com/MX/Networks_and_Routing/MX_Layer_2_Functionality#LACP_.26_Link_Aggr...
P4ck3ts
thank you. i was looking at the wrong doc.
GreenMan
P4ck3ts
thanks!
ChristophJ
LACP isn't supported on the MX. But there are topologies that Meraki recommends with Spanning-Tree:
You can find them in their documentation:
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair#:~:text...
