STP Discarding Packets from the Switch Port
Azar
How do I resolve this?
DarrenOC
Does your Nvr have two ports?  What you’re seeing could be normal behaviour based on your setup.  If there are two ports into the nvr then one port will be active and passing traffic the other will be blocking and so discarded packets.
DarrenOC
Azar
Hi DarrenOC,
The NVR have the two LAN ports which are connected in two different switches. As you said in the NVR one port is in active state and other port in blocking state. If one port fail the traffic will flow by the other port.
Thanks for your response.
DarrenOC
Hi @Azar , thank you for the update.  What your seeing then is normal behaviour.
Azar
Hi DarrenOC
Yeah it is in normal behaviour only.
