Search instead for
SNMP: Identify Switchport negotiation
Hello Meraki Community,
I tested the direct, local snmp Access to a meraki switch. This was fine, a snmpwalk for example is possible.
But it is possible to identify the current port negotiation (Speed/Duplex) on the switchprts? MIB, OID?
Best regards,
Koray
7 REPLIES 7
Re: SNMP: Identify Switchport negotiation
Yes, you can some informations through snmp, this is what we can see with our tool, only for active ports:
Grüss dich Marc,
Which Solarwinds tool is this?
Would be cool to identifiy the snmpget command (oid) to get the Information.
Koray aus dem Ruhrgebiet.
Hi Guys,
I search the OID of the temperature.
An Meraki engineer told me that it will be possible, but they want spread that information.
Grüße aus Köln!
@MarcP what app are you using ?
I am looking for something to build a dashboard for a global network that will give me a faster response for events that the Meraki dashboard which tends to have a lag of about 3-5 mins.
It´s the PRTG - tool isn´t it?
For just an easy monitoring you can use ServersAlive. It can also check any OID.
@GaryShainberg Its solarwinds - orion monitor  (network performance monitor)
