Remove switches from a deleted network
RonD
I have 2 MS210 switches that have bee assigned to a test network that was accidentally deleted.  When I try to add them to a new network I am getting an error that the switches are already assigned to a network.  How can I remove them from the deleted network so I can use them again
7 Replies 7
Do you see the switches in the inventory, and not assigned to a network?
How long did you wait  after you deleted  the network
RonD
The switch shows in the inventory and is assigned to a network.  It was about an hour.
I think you can remove it from the network there if you using pdl licensing.
With co term license  i would create a support case
RonD
I managed to sort the issue.  The switches had just been moved to another network by a colleague and the data had not updated in the inventory.
GreenMan
Dashboard won't let you delete any Network with a device in.   I'm surprised the Inventory wasn't up-to-date pretty immediately.   Some stuff in Dashboard takes a while to percolate through, but not so much device locations and the Inventory.
This is the kind of thing that if you take a break, have a coffee, and then try it again it will work.
BlakeRichardson
Sounds like a classic stitch up by a co-worker.
Your co-worker
