How do add QOS (AF41) for Video so it sets the ToS value on ingress to the VLAN and give it priority in the Network?
Thank you
Richard
Here is a example, if you know the ports used
https://documentation.meraki.com/MS/Other_Topics/MS_Switch_Quality_of_Service_Defined#How_is_DSCP_ta...
Hi
This is the doc I followed and not seeing the ToS value change in Wireshark. That does the Marking and should change the ToS value on ingress to the Port.
Still trying to figure out how you give AF41 Priority on the Network .
Thanks!
Just set to UDP and any ports now works ToS now 0x88 AF41, guess its a bug in Meraki that is does not match on the Port Number!
No how to apply that to Meraki Network.
I hope you were capturing on the destination port then 😉If you click the green link (DSCP to CoS mapping) you have control over what DSCP value goes into which queue.
