Port Profile Bugs
Dunky
Port Profile Bugs
I started to implement these today but have given up as they appear too 'buggy' to me.
I set the port profile as below, note the STP Guard setting
However when comparing once its been applied to a port, the STP Guard shows as "n/a" as shown below:
Also, if you edit a port and disable the port profile, it still shows up when viewing switch ports:
Also, the profile will not let you have a blank Native VLAN which the port itself does
Furthermore, even if you disable the port profile on the ports, when you then edit the port profile, it says it will be applied to 'n' ports.
So I will park it until these anomalies are fixed
Ryan_Miles
Meraki Employee All-Star
You can open a case. But I will say I've already confirmed with MS PM these things are already known and being worked on. So a case isn't going to really help much in this instance.
5 Replies 5
I suggest you open a support case.
Dunky
Done
Ryan_Miles
Dunky
OK, thanks Ryan.  Seems it was released a little prematurely 🙂
GIdenJoe
I also noticed no support for port-security in the port-profiles setting.
