Port Mirroring
Shadius
Port Mirroring
Hi, all,
We've configured all of our ports of our core switch (MS425-32) to be mirrored to a destination port on the same switch. The destination port has a device connected to it that is being used to capture the traffic from the source ports.
The issue that we're having is that the traffic shows the IP address of the wireless access point instead of the IP address of the client that is connected to the wireless access point.
How would I be able to achieve this?
Kevin_R
Meraki Employee All-Star
Hello Shadius,
Is the issue that you are seeing the AP's IP for the 2 SSIDs using Meraki NAT mode or for all 3 SSIDs? It is expected for the 2 SSIDs using Meraki NAT mode, as the document that Brash shared explains.
Meraki NAT mode means that the AP provides IP addresses to clients connected to the SSID from the 10.0.0.0/8 subnet via DHCP. When a client sends traffic out to the network, the AP NATs the client's IP to its own management IP, masking what client actually sent the traffic. There is no way around this when using Meraki NAT mode either; client devices cannot be tracked behind NAT mode enabled SSIDs.
The bridge mode SSID, on the other hand, should not have this issue. You should be able to track clients connected to the SSID, as the client IPs are used within the wider network.
5 Replies 5
Brash
Is the SSID the clients are connected to setup in Meraki NAT mode?
NAT Mode with Meraki DHCP - Cisco Meraki Documentation
Shadius
We have three SSIDs and two of those three are set up using Meraki NAT Mode.
The other SSID uses RADIUS with an external DHCP server.
Kevin_R
Hello Shadius,
ChloeGray
Thanks for the info, I appreciate you.
XavierRoss
Any update?
