I have a security appliance that uses port mirroring. I setup the port mirror and then am unable to access the appliance connected to the destination port. Can not see why I would not be able to access the device, is there some configuration that I missed when setting up the mirror?
Are tou trying to access the security appliance using another port? Or using the mirror port?
Using the mirror port.
I have this setup on another LAN with a non Meraki switch and the appliance on the destination port and can access the appliance. Is this a limitation on the Meraki?
Afaik on most verdors a mirror port only send data.
"Note: Clients connected to a destination port of a port mirror will not have network connectivity, as the destination port will not serve clients."
Thanks WW, a little disappointing but at least breaking and remaking the mirror is a quick job.
Had the exact same issue at a site moving from an HP/Aruba switch to a Ubiquiti (let me just wash my mouth out!).
The device was accessible when on the HP/Aruba switch, but not once moved over to the Ubiquiti.
