Offline Configuration
MithleshDhoke
Hi
Is there a way we can configure Meraki devices offline.
If we perform routing changes for default route in Core switch, it might lose connection to Meraki Dashboard, in that case, can we perform configuration changes offline?
Regards
No, it's not possible. Meraki devices are managed by the Meraki Cloud.
The management vlan of the (core) switch should not use the default route of the core itself. Use a seperate layer2 vlan to the (internet router/firewall)
MithleshDhoke
Thank for response ww.
We have same vlan for Management and default route in current configuration of core switch. So, we need to change the default route pointing to SDWAN cEdges as well as Management LAN IP for core switch.
