Noob Routing Question
wjonline1975
into my first hour with meraki switches : MS250-24P.
I have my management interface on vlan1 and it has been assigned an IP via DHCP, and thus it can route out and connect to the cloud.
so I see the switch online and all looks good.
I want to add vlan 50, so I assigned a port as access and placed it into vlan 50.
I want to make vlan 50 a L3 vlan, so I click on "configure layer3 settings".
I get presented with a screen that states:
"You don't have any interfaces or static routes configured
Create an interface to configure layer 3 settings on your switch", so I click.
I select the switch from the dropdown and the following details:
name = "v50"
subnet = "10.10.93.0/24"
interface IP = "10.10.93.254"
default gateway = ""
vlan = "50"
then hit save
I get the following error message?
"There were errors in saving this configuration:
  • The interface on 10.10.93.0/24 overlaps the interface on 0.0.0.0/0"
any ideas, im stumped?
I guess You did not inserts the default gateway so it cant create the default route to that gateway ip.
https://documentation.meraki.com/MS/Layer_3_Switching/MS_Layer_3_Switching_and_Routing
2 Replies 2
wjonline1975
Hi
So from what you have said that the vlan1 interface that has received an IP via DHCP and does have a gateway is not installing a default route into the routing table?
thanks
