LACP group across 2 MS450s
stewdickson
Hi there,
Just looking to check functionality on MS450s.
Can I create an LACP group across 2 physically/flexibly stacked MS450s? And if so, how many ports can I have in the group?
Thanks!
DJDonovan
Meraki Alumni (Retired)
Hey Stew!
All Meraki switches support LACP groups of up to 8 ports, and as cmr said you can do so between physically stacked switches.
Further documentation on our implementation of LACP can be found here:
https://documentation.meraki.com/MS/Port_and_VLAN_Configuration/Switch_Ports#Link_Aggregation
Let us know if you have any other questions! 🙂
-Donovan
2 Replies 2
Across physically stacked - yes for sure
DJDonovan
Hey Stew!
-Donovan
