Newbie - switch/router connection
AVIF
question from a newbie here - got an MX84 and 3 MS-120 switches.
What's the best practice to connect the switches/router?
a. connect all 3 switches  to the ports on the MX
b. connect each switch into the next one and the last switch in the MX?
c. connect 2 switches into the first switch and then in MX?
Not sure what's the advantage of the different connections would be.
1 REPLY 1
Re: Newbie - switch/router connection
@AVIF as the MS-120s cannot stack, I'd connect each to the MX with two cables if traffic is mainly to the internet.  If traffic is mainly internal then is connect the switches in a loop A-B, B-C and C-A.  Spanning tree will block one connection, then connect one MS to the MX.
