Network Topology - Incorrect
Marcel_Smal
Good day Meraki-verse,
I am wondering if anyone else has experienced an issue with how the topology view gets populated in the dashboard. I have a network with Cisco Catalyst Monitored switches, and it seems that the topology in the dashboard is not correct. How is this map populated with CDP and LLDP?
The topology should look like this:
However this is the current topology view in the dashboard!
It does not look close to my diagram. So has anyone else had a similar issue?
Regards,
Marcel Smal
IvanJukic
Meraki Employee All-Star
Hi @Marcel_Smal,
Try disabling CDP on the Catalysts and topology will slowly correct itself with the LLDP information.
https://documentation.meraki.com/MS/Monitoring_and_Reporting/Network_Topology
Drawing from my experience, if there is no funky STP stuff/design happening. It'll be fine. I've seen this with plenty of non-meraki, 3rd party vendor devices looking beautifully.
Cheers,
Ivan Jukić,
Meraki APJC
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
7 Replies 7
BlakeRichardson
I've seen the topology go a bit weird when you have non-Meraki gear in the mix. Also if you have equipment from one network connected to equipment in another that can draw oddly as well.
DarrenOC
I try not to rely on the topology maps within the dashboard.  Firstly, they’re not cosmetically appeasing and secondly they throw they’re own little quirks.
IvanJukic
Hi @Marcel_Smal,
Cheers,
Ivan Jukić,
Meraki APJC
I just learned something.
Marcel_Smal
Hey Everyone,
Thank you for the tips I just did this and by disabling cdp and only having LLDP active it started to correct the topology. Thanks for the help everyone!
Kind regards,
Marcel Smal
IvanJukic
Glad it worked for you. I'd love to see an update version.
Cheers,
Ivan Jukić,
Meraki APJC
