We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
I need to add multiple VLANS to a port on a switch.
On a access port u can use 1 native and 1 tagged(voice) vlan
If you want more vlans you need to configure a trunk port
https://documentation.meraki.com/MS/Port_and_VLAN_Configuration/Switch_Ports#Port_configuration
I should have been more specific. I have an MS125 and I need to have multiple VLANS on an access port
Not possible, you have to use trunk port for that.
@DaleSmithGuy why do you need it to be an access port? A trunk port with a native VLAN is just an extended access port in most ways.
By the very definition of an access port - not possible.
For example - the switch receives a packet - how would it know which of the VLANs to place it on?
