Meraki and Linksys
Raul_Umana
Meraki and Linksys
I everyone, I have a Meraki-MS2250P switch and a linksys LGS352C and I want to connect them by a SFP fiber port, do you know if this is possible?
Many thanks in advance.
Mloraditch
This should work as long you use compatible but matching (speed/duplex/media type) sfps at each end. I.e. if you use a Multi Mode MA-SFP-1GB-SX on the Meraki you need to use a multimode linksys compatible sfp on that end.
Here is the Meraki SFP list:
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Small-Form_Factor_Plu...
I will say I've never not had a third party sfp work on my Merakis but officially the above link is the only supported hardware.
Mloraditch
Also make sure the Linksys switch has its spanning tree set to STP mode and not MSTP or RSTP.
Raul_Umana
I appreciate your comments.
Best.
