Meraki Switch WAN Breakout
ToryDav
Does this design seem copacetic? Right or wrong? I know these are not ideal for breakout switches.
The WAN side looks good to me.
Assuming the two MS355s are in a stack:
Personally, I would only connect each MX to a single MS355 otherwise you can introduce spanning-tree loops by connecting each MX to both MS355s.
I personally feel you are more likely to have an outage due to a spanning tree issue than a single discrete cable or port failure.
ToryDav
Thanks @PhilipDAth
I was thinking about that too. They are set-up like the diagram now. STP is blocking where it should be with the redundancy between the MX and the 355's, but that is good point. The 355's are stacked. I can advise them to remove two links like you mention to reduce potential STP issues from occurring, but so far so good.
I was concerned about using the public IPs on the WAN switches. Any concern there beyond locking down the local status pages on those devices? Not a huge fan of public IP's on the WAN switches for management personally.
I have done exactly this before.  When I have done udp and tcp scans using nmap from a remote subnet I get zero response.
ToryDav
*Sigh of relief*
