Meraki Simulator
NipunKumar
Meraki Simulator
Hello All. I am new to Meraki. Can anyone please suggest Simulator for Meraki Patrice.
I mean for Patrice how do i add different devices in Dashboard.
BrandonS
Also, if you work for a Cisco partner or have access to Cisco.com you can check out dcloud.cisco.com where they have live demonstrations available for Meraki and many other Cisco things.
5 Replies 5
BrandonS
Did you try this? https://meraki.cisco.com/form/demo/
Best
BrandonS
DarrenOC
Agree with @BrandonS , dcloud is your best option here. Will give you plenty of hands on using the dashboard.
Or, look at one of the Meraki courses, 365, ECMS etc as these contain plenty of learning material and labs.
NipunKumar
Thanks a lot for your valuable response.
NipunKumar
Thanks a lot Sir for your support.
