Meraki MS130 support IGMP snooping
lc-gabriellima
Does the Meraki MS130 support IGMP snooping on access ports for multicast configuration?
I couldn’t find a clear reference in the official documentation, and the MS130 is not listed in the Meraki "Switch Feature Availability by Model" page.
If anyone has tested multicast scenarios with the MS130 or has confirmation from Meraki support, does it actually perform IGMP snooping, or does it just forward IGMP traffic as plain Layer 2?
Any clarification would be appreciated.
2 Replies 2
Mloraditch
Per this document: https://documentation.meraki.com/MS/Other_Topics/Multicast_Overview%2C_Configurations%2C_and_Best_Pr...
"IGMP snooping is now available on all platforms"
I have configured this in environments with MS130s.
GIdenJoe
Important note to make:
While all switches do support IGMP snooping this does not guarantee a multicast installation will work.
You still need a device like a switch that supports L3 interfaces as SVI's or a upstream router/firewall that does the IGMP querier function or PIM routing function.  Without this you won't have much luck getting your multicast between switches.
Also good to know: MS switches do not support fast leave in IGMPv2.
