Meraki Dashboard Configuration Templates
drgriff2000
Hi Team,
Have a customer that is unable to create templates. Specifically the option does not exist in the local Network>Organization>Configuration Templates. Does not exist.
Is there levels to dashboard options?
OR is this feature found only with Security - SD-WAN.
1 REPLY 1
Make_IT_Simple
it is a little different with switches, you need to create a profile. This document can help you get started:
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...
