We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
Hello all,
I'm looking for a whitepaper or a config guide to integrate NAC on Meraki MS switches with clearpass. I appreciate all the help I can get.
Kind regards
Jurgen
@Jdnd : Not sure if it helps, i only thread i got on Aruba Integration
https://community.meraki.com/t5/Off-the-Stack/Aruba-ClearPass-integration/m-p/5685
Well you could start by reading this document:https://documentation.meraki.com/MS/Access_Control/MS_Switch_Access_Policies_(802.1X)
There you see what radius attributes the MS switches can respond to.The rest should be pretty straightforward.Adding switches as radius clients.Adding matching rulesAdding results that contain supported AV-pairs.
