@whistleblower if all the interfaces are the same speed then port buffers shouldn't matter. The only time that the buffer size should come into the equation is when you have different speed ports talking to each other, or are saturating either inter-switch or stack links. We have had several storage providers request large buffers to fix issues on iSCSI SANs and as yet the buffer size has NEVER ended up being the issue...
We have been replacing Cisco 3850s with MS355s (stacked) and haven't noticed anything negative in terms of performance. In theory every port in a switch should run close to wire speed, with the only obvious bottlenecks being stack or other inter-switch links. Routing should not cause performance slow downs either in our experience, even on a L3 MS210 stack we have.
