MS390 dedicated management interface usage
Darren8
I've looked at the documentation but it's not clear exactly what this interface is used for.
Can it be the cloud uplink?
Can you connect all of them from a stack for a dedicated redundant cloud uplink?
It doesn't appear to work as a management uplink out of the box.
Thanks, Darren
1 Reply 1
AjitKumar
Hi Darren,
I never got an opportunity to configure MS390 yet. However documentation suggests, this is a management port to access the switch "Local Status Page". This does not seem to help the device reach the cloud.
Kindly refer to the below URLs if already not.
https://documentation.meraki.com/MS/Installation_Guides/MS390_Series_Installation_Guide
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Using_the_Cisco_M...
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
