MS355 Series Switches 10Mpbs?
Dkurtz
Is it possible for the MS355 Series Switches to be configured to support 10/100Mbps PoE on specific ports?
If yes, can you please direct me to the appropriate configuration documentation?
I really appreciate any information on this subject.
Thank you!
Johnfnadez
Just make sure that U have the auto negotiation enable on the switchport.
Johnny Fernandez
Network & Security Engineer
CCNP | JNCIP-SEC | CMNA
8 Replies 8
Johnfnadez
When you connect a link In your switchport. It will negotiate speed against the device connected. So don´t worry about it. You have a switch that will support this speed without issues.
https://documentation.meraki.com/MR/Other_Topics/Ethernet_Link_Negotiation_on_Cisco_Meraki_APs
Regards
Johnny Fernandez
Johnfnadez
Johnny Fernandez
Dkurtz
Thank you for the snappy response John. Greatly appreciate it.
To be clear - an MGig port will not support 10Mb/s or 100Mb/s,
So if you need this select an MS355 that also has standard Gigabit ports and use one of those.
Dkurtz
Philip, thank you and understood. I'll go verify the specific model before proceeding.
GIdenJoe
@PhilipDAth, small correction
Indeed mGig ports do not support 10Mbps anymore but they do support 100Mbps just like the mGig Catalyst switches do.
Also from the datasheet:
Multi-gigabit (mGig) ports support 100M/1/2.5/5/10G of bandwidth over copper cabling
@Dkurtz you can force 10Mb full duplex on the 1Gb ports but you cannot force 10Mb half duplex which has caught us out for one old device, time for a crappy hub I think...
Dkurtz
John, apologies but I was just updated. Apparently the device we are connecting to does not support auto negotiation. Is there a way to "hard-code" the 10Mbps to a specific port?
