At a time only one VLAN can use the static route corresponds to the same subnet.
other VLANs worked with own dhcp range but with dns issue.
that is the reason we look to add static route for each VLAN.
Here all VLAN has own dhcp..at current only one VLAN which has one static that becomes default is working fine with dns.
when we tried to add more static route for each VLAN inorder to get proper gateway..system shows error the subnet already routed.
