MS225/250: Stacking with QSFP Modules
Hi community,
is it possible to use QSFP modules (e.g. MA-QSFP-40G-LR4) for stacking via fiber optics with the MS225 or MS250, or is this only possible with the 40G TwinAx cables?
Best regards,
Andreas
Accepted Solutions
Re: MS225/250: Stacking with QSFP Modules
4 REPLIES 4
There's no documented support for that. To be tested if in practice it works, but I doubt it.
as previously mentioned, its not documented so not supported.  I would stick to the MA-CBL-40G cables.
Darren O'Connor | uccert.co.uk
Thanks for your replies!
