MS210 48LP and 48FP PoE standards
Jyrki_Halonen
hi,
are MS210-48LP and MS210-48FP both 802.3at (PoE+) compatible models? I know that FP model is.
Yes, it simply has a lower total combined power output.
Jyrki_Halonen
thanks @cmr for clarification, that was what I thought also, but couldn't find straight answer from data sheets
FeliA
Greetings @Jyrki_Halonen,
@cmr is correct. Both models support PoE+.
The MS210 Overview and Specifications documentation provides a breakdown of PoE capabilities by model, along with other model-specific details:
Have a great day!
Best,
Feli
If you found this post helpful, please give it kudos. If this answer helped solve the issue, click "accept as solution" so that others can benefit from it.
