MS130-48X Port profiles help - UI not updating correctly!?
YoinkZ
Hi all,
I'm currently setting up new Meraki MS130-48X switches for the first time and was looking at the ability to use Port Profiles.
So far I have been able to create the different Port Profiles as either a Trunk or an Access ports with the desired VLAN(s).
As shown below, you can see one of the Profiles are set up as an Access Port (VLAN105)
But, when I head over to my Switch and want to configure a set of Ports that should be a member of that Port Profile then it shows my type as "Trunk". Could just be the UI not updating correctly, or have I done something wrong?
Here is a picture of how the Ports settings are set:
Thank you...
Ryan_Miles
Meraki Employee All-Star
Yes, this is one of the several known issues at the moment with port profiles. The other common one that people see is when you disabled a port profile on the switch port list page it still shows a profile in the profile column, which can be slightly misleading.
5 Replies 5
RaphaelL
Hi there ,
I think this is expected for the moment. The switch port will display the port config and not the overrides done via PortProfile. But I suggest you open a case just to make sure
YoinkZ
Alright! Thanks for a quick response.
I have submitted a ticket with the above information. I will post when I have an answer.
Ryan_Miles
YoinkZ
Hi Ryan_Miles.
Exactly - I hope that it will be changed or at least be a feature/setting where you can toggle it on or off. I would rather know what my current setting is, not what it was.
YoinkZ
As promised here is the answer from the Support:
This type of behaviour is expected when using port profiles and templates, please refer to the following documentation that states this behaviour: https://documentation.meraki.com/MS/Port_and_VLAN_Configuration/Switch_Port_Profiles#:~:text=The%20c...
As highlighted in the blue box, this is expected and I was advised to use the Feedback option from the Dashboard which I did. Maybe we will see some changed one day :).
Thanks everyone!
