MS130-48P: All ports connected to APs are down
mcoomber
I've got 5 MS130-48P switches working within the LAN.
However yesterday, one of the switches went offline without any configuration change. This is the switch where the APs (MR44) are connected. After rebooting the switch came back online but all the APs are down. Other devices connected to the switch are on. Log shows the Port status change from designated -> disabled
The ports connected to the APs are Access Ports with RSTP enabled and STP guard disabled.
When the APs are connected to the other switches they come online.
7 Replies 7
Did the switch ports show they were supplying PoE?  Did the MR44s power up?
mcoomber
Yes, the ports showed they were supplying PoE. They are powered up.
Could you see the SSID?  Could you connect to the SSID?
When you say all the MR44s were down, what specifically was going wrong?
mcoomber
The SSIDs were off.
The LED lights on the  APs were in a blinking mode.
From the dashboard they were showing No connectivity.
However once I changed the switch to which they were connected, the SSID was available and users could connect.
Nibss
Do they work in a trunk port configuration. Are you working with SSID's on different VLANs?
Check the route bridge of your switches sounds like a potential spanning tree issue.
Check the uplink configuration on the switch you are having issues with.
Honestly, need to see the full topology & understand where your gateways are situated to look at this in detail.
Can you ping the gateway the AP's are using from the switch having issues via the dashboard? Check there are no duplicate IP's on any gateway devices (I once had a Meraki access point manage to steal a gateway IP after a device rebooted and lost its lease after a power outage).
mcoomber
Hi Nibss,
I have attached the config of the 3850 switch to which the MS130-48P is connected. I've also attached the screenshot of the config of the Uplink port and the config for the switch.Uplink port configUplink port configScreenshot 2024-10-26 094527.png
Currently used config even though static settings are applied.Currently used config even though static settings are applied.
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
service compress-config
hostname BACKBONE-SW
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5
username admin privilege 15 password 7
aaa new-model
aaa session-id common
switch 1 provision ws-c3850-24t
ip name-server 172.16.0.2
ip name-server 172.16.0.3
qos queue-softmax-multiplier 100
vtp mode transparent
crypto pki trustpoint TP-self-signed-311815890
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-311815890
revocation-check none
rsakeypair TP-self-signed-311815890
crypto pki certificate chain TP-self-signed-311815890
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
diagnostic bootup level minimal
spanning-tree mode mst
spanning-tree extend system-id
spanning-tree mst configuration
name OfficeHQ
revision 1
instance 1 vlan 1-30
spanning-tree mst 0-2 priority 16384
hw-switch switch 1 logging onboard message level 3
redundancy
mode sso
vlan 5
name VOICEVLAN
vlan 10
name DATAVLAN
vlan 15
class-map match-any non-client-nrt-class
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface GigabitEthernet1/0/1
description "SERVER ACCESS PORT"
switchport access vlan 10
switchport mode access
spanning-tree portfast
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
switchport access vlan 5
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
description "UPLINK TO ACCESS SW"
switchport mode trunk
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface Vlan1
ip address dhcp
interface Vlan10
ip address 172.16.0.10 255.255.254.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
line con 0
password 7
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7
transport input telnet ssh
line vty 5 15
ntp server 172.16.0.1
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
ap group default-group
end
mcoomber
Hi Nibss,
Please find below the config on the 3850 switch and the settings as applied to the MS130-48P switch.
Settings on the Uplink PortSettings on the Uplink PortConfigured Static SettingsConfigured Static SettingsDisplayed Settings currently in useDisplayed Settings currently in use
BACKBONE-SW#sh config
Using 2684 out of 2097152 bytes, uncompressed size = 5832 bytes
! Last configuration change at 18:24:23 UTC Mon Oct 14 2024 by admin
! NVRAM config last updated at 12:02:19 UTC Fri Oct 25 2024 by admin
version 15.2
no service pad
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5
aaa new-model
name OfficeHQ
revision 1
redundancy
mode sso
vlan 5
name VOICEVLAN
vlan 10
name DATAVLAN
vlan 15
no ip address
negotiation auto
interface Vlan1
ip address dhcp
interface Vlan10
ip http server
line con 0
password 7
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7
line vty 5 15
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
transport http
transport https
end
