I've got an MS120 telling me it sees a MAC address on Port 57 (which is actually on port 9). Several other entries are supposedly on ports 52-54 as well.
Thing is, this thing only has 48 ethernet ports + 4 SFP slots. None of the SFP slots are in use.
Something buggy with the dashboard today?
EDIT: This is happening on at least four different MS120's at separate locations. Neato.
Solved! Go to solution.
Got an update on my ticket yesterday that this issue has been resolved. After spot checking a few of my MS120's, it looks like this has been addressed.
What version are you running? Have you opened a support case?
14.33.1, no support case just yet.
There are a lot of known issues with this version. I can try to update to the last stable version.
Same here. MS120-8P
Clients are shown on port 49-53 despite having only 8+2 ports. Running MS15.21.1 ( latest firmware ).
We should open a ticket about this.
Thanks for confirming it's not just something weird that only we are seeing. I've opened a case with support. If any Meraki folks are haunting the forums and want to take a look, this is case #09582507.
That's why I prefer the good old CLI.
Come on boomer. Haha. 🙂
Had a little back and forth with support about rebooting switches and updating from MS14.X to MS15.X. Was able to show them a reboot has no effect, and that this issue is present on both flavors of MS software.
The MS team is aware of the problem and are looking into it.
Yes. Also resolved on my side.
I see this often on my MS225s
