MS switches performance with 3rd Party Router for Overlay
Alannabi
Hello Team,
How are you doing?
I have a customer who will order Meraki Switches (MS120), we are fighting to let him replace the Routers he has (which rented via AT&T) with Meraki MX.
my question:
will be there any technical issues with the MS switches (from a management perspective) if he insists to keep using the 3rd party routers?
MCITDept
Alemabrahao is correct, you can use any router with Meraki Switches, we did for a few years before moving over to the MX devices.  I hope you can get them talked into using the MX, as you probably know already, they are nice to use if you already have the switches in the dashboard.
2 Replies 2
You can use any other router from any other manufacturer and you won't have any management issues.
MCITDept
