MS Group Policy - Syslogs
RaphaelL
Hi ,
We are currently using Group Policy on our MS switch via RADIUS attribute ( https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Creating_and_Applying... )
Is it me or the L3 firewall from the GP is not triggering syslogs ?
Our security teams are concerned about the fact that there is no logs generated.
I dont know the answer, but i would like to know 🙂
My assumtion here is that syslog only logs flows.  But group policy and switch acl both uses stateless rules(like a acl). And therefore there will be no flow logging
RaphaelL
That actually make more sense than expected 😁
KarstenI
Another assumption: Switch ACLs don‘t log because sending the Logs is a Control/Mgmt-Plane action. The frame had to leave the HW switched data plane to send the logs.
GIdenJoe
You'd be lucky if you at least have a screen that shows ACL hits on a switch.
Switches use ASIC's where statelessly forward frames so no CPU involvement.
You need CPU for logging.
If you really need logging you'll need to have this in your network design.
For example security between VLAN's that don't require logging can be routed on the core switch.
The rest need to be forwarded to a firewall.
In Cisco designs (not Meraki) you have multiple VRF's on your coreswitches and you can then have networks that need to pass an upstream firewall on different VRF's and then you don't need to stretch your layer 2 over your coreswitch which is in fact not the best design.
