I've looked into this further, and I believe if you use MA-SFP-10GB-LR on the Meraki side it will be compatible with SFP-10G-LR-S on the small business side.
The "-S" optics have the same lasers as the non "-S" models. The only real difference is the "-S" models don't support FCoE and are only designed to operate at "commercial" temperatures.
You can read more about the "-S" differences here:
