Lorex Camera port keeps staying down
ozamora
My port for a Lorex camera keeps staying down. Typically when this happens a power cycle of that port fixes it but this time it has not. MS320-48LP. Any suggestions on how to fix this? I've tried a different patch cable as well
1 Reply 1
ConnorL
Meraki Employee All-Star
I'd advise to open a Support case if you haven't already, as Support should be able to take a look at the state of the PoE.
Also worth trying to move the camera to a different switch port, if the issue still occurs you may wish to reach out to the manufacturer to determine if there any known compatibility issues, or PoE specifics that may be causing this issue.
