Live 802.1x authentication + dynamic VLAN
DADA
I am unable to drop into a dynamic VLAN for wired 802.1x authentication.I do not know if Meraki is incorrectly configured or Radius is incorrectly configured.Is there any clear documentation?
MartinLL
You need to enable and configure VLAN profiles for dynamic vlan assignment.
VLAN Profiles
MLL
DADA
@MartinLL
Where do I set it ?
Is it Meraki ?
Is it radius ?
MartinLL
You create VLAN profiles under network-wide > VLAN profiles. There you can add VLAN name to VLAN ID mapping.
After that you need to return the VLAN Name form your RADIUS server to the Network Access Device during client authentication.
MLL
MS switches can dynamically assign a VLAN to a client device by configuring the switch port to use the VLAN ID received via the RADIUS attribute Tunnel-Pvt-Group-ID
https://learn.microsoft.com/en-us/previous-versions/windows/it-pro/windows-server-2008-R2-and-2008/c...
https://documentation.meraki.com/MS/Access_Control/MS_Switch_Access_Policies_(802.1X)#Dynamic_VLAN_A...
