Limit bandwidth on port basis
Orlando92
We have a customer that wants to hardwire all guest rooms directly to the switch.   I know we can do PORT ISOLATION on the MS appliance, however the client wants to know if they can limit the bandwidth on a per port basis – any ideas?
Jorge O Munoz
BlakeRichardson
Not on a switch no. If you are using an MX as the router then you can do it through that.
BlakeRichardson
Inderdeep
@Orlando92 : switch ports are not intended to limit on the bandwidth. It is always on the WAN device which is MX as rightly said by @BlakeRichardson
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
Orlando92
Thank you where can I find documentation on this? is it just traffic shaping?
Jorge O Munoz
Make_IT_Simple
Meraki Alumni (Retired)
