Initial MS Setup - connecting to a Cisco traditional switch
MerakiMed
I have an a 48 port Meraki MS and to initially set it up I will attach it to
a Cisco 4510 switch. Is it possible to connect the Management port of the
Meraki to a 4510 switch port in access mode? Or is that Management port
just for local laptop to switch connectivity?
Ryan_Miles
The mgmt port is just for local connection with a laptop as you mentioned if you need to give it a static in order for it to reach dashboard. Otherwise the switch will pull DHCP for its logical mgmt interface which is the common way folks deploy Meraki switches (and APs, cameras, etc).
2 REPLIES 2
Ryan_Miles
Inderdeep
@MerakiMed ; check out
https://documentation.meraki.com/MS/MS_Quick_Start
Regards/Inder
www.thenetworkdna.com
